fuel line
bandannarob
where can i find the hose that goes from fuel pump to filter on 1989 mercury 70 hp. mine blew a hole in it yesterday
JustJason
Re: fuel line
Anyplace that sells boat parts. If you have an exposed portable tank you can use the cheapie grey stuff. But if you have a semi permanant tank you really want to use B1 rated fuel line.
bandannarob
Re: fuel line
sorry, i'm talking about molded line on motor
robert graham
Re: fuel line
Looks like a piece of the correct diameter marine fuel line would work there, doubt that radius shown in photo would require a molded hose. Looks like an easy fix. Good Luck!
rosser1
Re: fuel line
it once was flexable, due to time, useage, and fuel it is now hard or molded. any fuel line with the correct dia. will work fine, may be hard to get it where it needs to go. looks like the old hose has expanded alittle. put a little wd40 inside new hose just where it needs to slide on fittings, you will be good to go. good luck!
