Fuel Line
73Steury
Does any one know the fuel line routing for a Mercury 135 inline 6? The motor has 3 carbs. My motor has been apart for over a year. We attempted to start it today but no fuel is getting to the carb's. If I remove the line from the tank to the lower pump and squeeze the bulb I get good fuel flow. The motor ran good when it was removed from the boat. I pulled the fuel lines off last year and lost my hose diagram.
Thanks
cr2k
Re: Fuel Line
It either goes between top and middle or middle and bottom, usually at whatever level the fuel pump is at. Should work either way.
