fuel lines
lynnboy021
I have a 89 omc gm 5.7 and I already put in a new carb plus fuel filter but now I want to put in new fuel lines.... so my question is can I just buy fuel lines from my auto parts store or does it have to be from west marine????
bigdirty
Re: fuel lines
If you are talking rubber fuel line, i've just gone to an auto parts store and got what i need, far as I know fuel line is fuel line.. :lol: about west marine, ya man, i know... they really take the 'Bust Out Another Thousand' thing too far right?
lynnboy021
Re: fuel lines
lol ya... I know not to buy marine motor parts from a auto parts store but I just thought like you said "a fuel line is a fuel line" but I did not know if it needed to say something like "marine approved" or "coast guard approved"
Re: fuel lines
Ayuh,.... Yes, they Do need Coast Guard approval,...
bigdirty
Re: fuel lines
What exactly is the difference? I might add that last time I replaced rubber fuel lines in a boat (feed from tank to fuel pump, not the filler neck/hose) I used automotive 'efi' rated line.. good for way more pressure than a carb motor will ever see, and its rated to live in an cars engine bay and survive moisture and temp changes, in a somewhat harsh environment..
(besides, the original line WAS cracked and leaking/sucking air..:laugh: i'm sure that boat is 'safer' now regardless..)
bonzoscott
Re: fuel lines
If from the pump to carb, I would get OEM line if I could. Or make it / have a shop make it. You can't put the flange on the ends without the proper equipment. If you figure out how much Stainless Steel line you need, a hydraulic shop can set you up with a straight piece, fittings and flanges installed. You then have to bend it right to fit your motor. I did my trailer breaks for about $30. Might consider getting excess in feet - you can always put curly ques in it to take up slack ($4 bend tool).
Re: fuel lines
Ayuh,.... I believe it's Fire Resistance,...
jerryjerry05
Re: fuel lines
The OLD OEM hoses were not Ethanol resistant.
They were a bit bigger/thicker.
Buy hoses from anyone as long as they are Ethanol resistant.
I bought a bunch of hose from Auto Zone and was told it was e resistant.NOT!
Needs to say it on the hose.
I ran a spare tank and used about 10ft of hose.When I pulled it to replace.
It looked like someone melted the outside layer.
It never leaked,but I'm sure it would have if it was touched or moved.
Grub54891
Re: fuel lines
Marine fuel hose is thicker,new stuff is alcohol resistant,the thickness is for fire rating. All steel lines should be stainless,lots aren't but that code has changed over the years,but have to be double flared. Anytime I see auto hose or copper tubing fuel line,I highly recomend to the owner to change it out,then it's up to them.
Grub
Georgesalmon
Re: fuel lines
Marine Coastie approved fuel hose is fire resistant and is less permeable to fuel vapors passing through it. It is NOT the same as auto fuel hose.
lynnboy021
Re: fuel lines
good info here.... I don't have any problems with my fuel lines but I don't know how old they are and plus I have new fuel pump and a new carb so I just thought hey what the heck I got new pump n carb I should just put new lines also...right?...
