fuel lines
Asterope8
I would like to find some new fuel lines that are for the choke system. There are four for my 1982 Evinrude 90hp. They go from the check valves located on the intake to the bypass covers.
boobie
Actually they are for the oil recirculation system. Try your BRP dealer as he should have it in bulk.
emdsapmgr
While that year's engine did have a fuel primer solenoid, the carbs that year may not have been made with the hose nipples for injecting the fuel into the top of the carb when choked. Around that model year OMC installed brass nipples on the bypass covers for the fuel primer hoses. Recirc systems may have begun in 83. The Bombardier fuel primer hose you need is part number: 772568 It is 1/16" ID whereas the recirc hoses are 1/8" ID. Should have a white stripe down the side of the hose.
