Re: Fuel mix for my 1952 johnson 10hp sea horse
The manual reccomends 1/2 pint of SAE 30W per gallon of gasoline, and they reccomend unleaded. That comes out to 16/1, which is what a bushing bearing engine needs to survive. I would be very leery to use anything less than 20:1, even with a modern TCW-3 rated oil. But I would use a modern oil (at the ratio reccomended by the manufacturer) as they are superior in dispersement, lubrication, low ash and have corrosion inhibitors as well. You cannot hurt it with too much oil, it will just smoke more, but you can easily spin a bearing and bust a rod with too little oil, don't risk it, play it safe.
