rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
Couple questions on my latest "build-up". 1987 Johnson 90hp. Good spark, 120lbs on all 4. Timing set good. This was a complete disassemble, rings, cleaning, paint-job and anything that needed attention.
1) Somewhat rough running at idle, and at elevated RPM's. No sneezing-just a bit shakey rough. Lots of smoking and very wet plugs. I Found fresh fuel seeping from front of carbs-I believe both. I will dig into them again.....I also had the butterfly's very slightly open at idle too, now corrected....But can this bowl overfill, really cause the rough running, and extra smoke? I'm thinking so.
Pic attached with a pointer of carb tubes where fuel is draining from. Current stand puts the motor at a slight angle under 15 degrees.
2) Power-head to adapter small exhaust leak....fresh everything (all apart, new gasket, bolts etc). I put on dry. Are double gaskets ever done here? Or I'm inclined to use a sealant when i pull the head again. leak is at the rear stbd corner where it meets the t-stat housing area. (all torqued to spec).
Thanks
Thanks
