fletchermerc1996
Thread starter- Joined
- Nov 24, 2009
- 19
Hi guys,
Well, I'm off to use our boat on Monday subject to weather etc. This will be the first time I have filled the tank, other than on the water, (as I am new to boating.)
Firstly, If i'm going to fill it at the petrol station, do I need to add the oil before the fuel to the tank, or can I add the fuel to a certain point and then add the correct ratio of oil afterwards?
I was only wondering from a mixing point of view, as I'm not sure if you add the oil afterwards, if it will mix throughout the fuel, which I'm assuming it would, if you added it first.
I will also be taking some cans which I can obviously pre-mix.
It was more the direct mixing in the fuel tank that I'm not sure about!
Thanks
Thanks
