Re: fuel mixture
Its been my experence that running 50:1 TCW type oils over the years has proven, at least to me, to be safe. In my almost 40 years of running outboards, I have only had one "break". That was a 1954 7.5, evinrude fleetwin, when I was 15. Its death was due to a wrist pin letting go. Was it from lack of oil? or just that many hours on it, without a tear down? who knows. Now I also look at how many outboards fail due to someone saying did I put in the correct amount of oil into the mix. Ok if I run 50:1 and I only add half that amount, then I now might be running to thin of a mixture.... and "bang', yet if I ran 24:1, i'd only drop down to 50:1. So maybe 24:1 is a safer mix. It sure isn't going to die of lack of oil, now is it? If I ran motors from the earlier years, pre 1950's, well I might run 24:1 or even 16:1, in an attempt to stop it from breaking due toan oil related failure,etc, yet since the motor is alread so old, chance's are it will breakdown if used regularly. No motor is about to last forever, all you can do is keep it well maintained, treat them with proper care, and hope it wasn't made on monday or friday....
I'll still recomend 50:1 for most motors, in the range of years, my experence has proven to be safe. Yet as :with all advice, it may not work in your situation.
