Re: Fuel or timing issue?
Another update. Swapped coils, plugs and wires around and #1 still not firing like the other 2. The #1 coil that looked weak still looks weak to me not popping and as bright as other still looks the same to me but is on #3 cyl and when i remove the wire that cyl drops alot unlike #1 when wire removed. Took comp. again to besure and all are around 100psi. sprayed a little fuel in top carb but did'nt change a thing. Like i said this thing ran great before timerbase went out and caused no start just hasn't run good since. What else?
