madlad
Thread starter- Joined
- Jun 30, 2010
- 29
I finally got to take the boat out I have been working on. Had problems getting it started, wasn't getting any fuel to carb. 1 or 3. Clean the carb's and finnaly got the boat started. When running it across the water, it was running very bad, couldn't get it up to running speed, without it falling on it's face, or barely running like it was starving for gas. Had the person with me I purchased the boat from and we played around with the timing and fuel. He had me drive the boat while he was fooling with the engine. He started pumping the bulb while we up the RPM and the boat started running really good. He said he thought it was in the fuel pump, as long as he was keeping pressure on the bulb the boat ran fine. I'm not sure if they will have a fuel pump in stock and I'm getting ready to go on vacation and want to take the boat with me. Can I put an electric in-line fuel pump on the boat to keep up the fuel pressure? If so what PSI would I need to use?
Thanks you guys for all the help.
Tony
Tony
