Fuel pressure too high, how to fix? Small block GM V8
arks
My Silverton has twin Crusader 270’s (350 Chevy small blocks). The port carb (quadrajet) was acting up so I bought a rebuilt one from an established shop. My plan was to install the new one and rebuild the old one over the winter for use as a spare.
So the new carb went on without any problem, and it runs perfectly when cold. However, when it warms up it starts idling rough and eventually dies. Talked to the rebuilder and he told me to check the fuel pressure because the carb is setup for a maximum of 5 PSI.
So I put gauges on and it measures 10-12 PSI. It has the typical mechanical fuel pump mounted to the block but there’s no way to adjust the pressure. Funny thing is this engine was running fine with the old carb- I replaced it because the carb body had developed leaks at the mating surfaces and was unsafe. I looked at those cheap automotive adjustable fuel regulators but they have a maximum input of 7 PSI, not to mention they’re not marine rated. Haven’t found anything else that would be appropriate for my application. I suppose I could replace the fuel pump but that, to me, seems like it might not solve this problem.
Anyone else have any better ideas?
Lou C
When you measured the pressure was the pump dead headed or did you hook it up so that the fuel went from the pump to the gauge then to the carb? The latter set up is the better way to check fuel pressure so you can get an accurate reading of actual fuel pressure with the engine running. I tested my pump (Sierra mechanical) &
Got 5.5 psi that way. Holley and others make decent fuel pressure regulators.
arks
Lou-I deadheaded it. I see your image in the second post and that makes sense to me, so I’ll get the borrowed gauge back and hook it up.
Don’t really want to mess with the starboard engine because it’s been running great and don’t want to change that.
I’ll report back once I get it done. Thanks guys, I can always depend on you for ideas!
Holley or carter 2-port fuel pressure regulator. Holley p/n 12-803 or Carter 404501HP most of them have zinc coated hardware. however a rattle can of engine paint takes care of that.
at 12 psi, the motor wont run cold or warm as the carb would be dumping fuel down the intake.
99yam40
I would think if there are no fuel pressure regulators then the pump itself would have something to control the pressure. that is why I mentioned checking the other pump to see what is shows
Lou C
It has to do with the stiffness of the spring and rubber diaphragm, but your typical mechanical fuel pump isn't adjustable.
I got lucky with the Sierra aftermarket pump in the pic above, it was putting out 5.5 psi, just about perfect for any carb.
Ayuh,...... I believe that's the reason some mechanical fuel pumps have one of those big thick plastic spacer, 'n two paper gaskets,.......
Instead of being mounted directly to the block, with only a thin paper gasket,.....
Bt Doctur
Well here`s one I could not figure out.Gm v6 mechanical pump
Occasionally after about a 1 hour run I would be leaving black smoke and running rough before it would flood out. Rebuilt the Rochester carb completely worked for about an hour and did the same thing. OK ,figured the carb was shot and installed the 1409 . an hour later it was doing the same thing after a run.
Installed a gauge to monitor the fuel system and when it was flooding the pressure read 19 psi for a mechanical pump
Cut the lines to the pump, left it in place and installed a electric one rated at 5-6 psi .That was 2 years ago and the problem never surfaced again.
Have not removed the pump yet because I dont have a blockoff plate .but if and when I do I will disect it with pics
Lou C
Now that’s interesting. So it ran high pressure at times but not all the time? What is it that was changing to cause that to happen….
