fuel primer pump ball questions
rentprop1
does the placement of the fuel primer pump ball thing matter in relation to where it is with relation to the tank and the engine ?
why I ask is on my pontoon boat the tank is permanently mounted at the port rear inside a compartment and the primer ball used to be about 6 inched from the top of the tank, I moved the ball to the outside of the compartment and replaced the 6 inch hose with a new hose about 18 inches long so I could pump the ball from the rear of the boat while on the trailer to flush the engine...I got sick of climbing up inside after a long day on the water just to prime the ball for a 3 min wash down.
after I moved the primer location I now notice the ball will not pump to firm, but each time I tried this the fuel was also pretty low in the tank, not empty, but pretty low
I checked all the fittings and connections all are tight and the fuel line was replaced with the correct size
thought and thanks
Silvertip
You can locate the primer bulb anywhere between the tank and the engine. It will work best when held or positioned vertically rather than horizontal. Just make sure the arrow on the bulb points toward the engine. Very often folks ignore this and then wonder why it doesn't work.
undone
And when in the vertical position the arrow should point up.
Triangleboater
Yeah I have a little 15hp where I work and hooked the fuel host the wrong way and I spent probably 30mins looked under the cowl and messing with the fuel tank. I will always look at the arrow from now on :facepalm:
Ayuh,.... Never thought of that, nor paid any attention to it,.....
Is that so's air bubbles purge more quickly,..??
roscoe
I believe it helps the check valves in the bulb work better.
I never had an issue with bulb orientation, until I bought a cheap one at kmart.
robert graham
I'm guessing those 2 ball check valves are spring loaded, but if not then holding the bulb in the "up" position could matter....I've always tried to hold mine at least a little "up" towards the motor....so far, so good!....
undone
They are not spring loaded (well some might be), the ball just floats in place and depends on flow and pressure differences to make a seal.
With the arrow point up it has a better chance of doing its job. I will say that most of the time its not a big deal, but can be at times.
