Fuel problem
birdseye418
while running the boat the primer ball will suck flat on any speed past idle, not just empty out but suck completly flat
i removed the check valve and it works fine, cleaned the fuel filter on the motor and replaced the fuel water seperator befor finding the bad gas
1st when i have removed all the gas i can from the in hull 30 gallon tank, how do i further clean it befor adding new fuel?
2nd. what would make the primer ball suck flat when the check valve is working and the tank vent is not clogged?
thanks
Jason
tommays
Re: Fuel problem
If you tee a vacume guage into the fuel line to see what is going on i would thing you will se a high reading (above 4" to 5" ) that would point to a probelm with the boats fuel system
It could be the pickup tube in the tank or the tank vent ect
matt2002
Re: Fuel problem
Make sure there are no leaks at the fuel joints/fittings.
Yamajoe
Re: Fuel problem
most likely an airleak in your lines from the tank to the connector.
