i was on the lake yesterday, i started up let it warm for a minute idled out of the no wake zone then got on plane, made it about 200 yards then motor sputtered and died. i cheacked everything over re primed and it ran for a couple min then died, motor runs fine if i pump primer bulb every 20-30 sec as i run on plane. does this sound like a fuel pump problem or carb problem. this is on a 1985 evenrude 150xp it has a VRO pump but oil line is capped and i mix fuel 50:1. i was thinking about replacing VRO with a regular fuel pump. any advice will be greatly appriciated
