FreeBeeTony
- Joined
- May 15, 2002
- 3,995
Have Twin '95 175 Johnsons.
Have a problem w/ the Starboard engine, stalls out when throttling up. If I let it idle long enough it will die, but start right up when I hit the key, although it does idle rough and at a lower RPM than normal.
Had to limp home on 1 engine today. While coming in I started playing with the "choke" (pushing the key in) while trying to throttle up in gear. By alternating advancing the throttle and pushing the key in I was eventually able to get up on plane and get to full throttle. I was able to repeat this condition multiple times.
I don't think it's the fuel pump because I was able to get to full throttle, and I don't think it's the carbs either.
I have heard of problems with the vapor separator on these engines. Is there a rebuild kit like a carb kit available?
