Fuel problems or what?
tomil
Hi, I ran my boat with Johson 40 VRO -1987. I've got this problem for quite a long time and now I want to fix it before season starts here in Finland. My actual problem is this; motor rans normally, however every time when throtle is in surtein position, motor do run normally for a while and then decreases RPM. Could it be throtle related promlem or
Please advice
Tomi
EN2
Re: Fuel problems or what?
You should start by checking compression, check spark,should jump to ground 12mm, bright blue lightning like snap. Let us know what you come up with.
EN2
You should start by checking compression, check spark,should jump to ground 12mm, bright blue lightning like snap. Let us know what you come up with. compression numbers should be 125-150 PSI.
tomil
Great! Thanks Seaman. I'll check this out as soon as ice has melted away :)
Cheers
Tomi
