I have a '97 Maxxum which we have been spending a lot of time maintaining/improving over the past few weeks. We added a water/fuel separator and everything seemed fine. Tested the engine out of the water, then put it in the water and ran it at low speed through the no wake zone. Went to open it up a little bit and it died. We bypassed the water/fuel separator and it still would not stay running, but when we took a little bit of the gas from the line and dumped it into the carb, the boat started and ran fine for about 5 seconds. It appears that there is a small amount of fluid in that tube going back up to the carburetor (it's nowhere near full though) so we suspect the diaphram gave out.
The question is should we just try to replace the diaphram or should we replace the whole pump? When we were going through and fixing things we also changed out the fuel filter. I was quite surprised to find that it had what's known as a "stone filter" and we read that it was ok to replace that with a traditional paper based filter.
We're just wondering - with all these changes-in-design would it be better to just replace the entire fuel pump?
TIA - this forum has been tremendously helpful!
