fuel pump change found milky oil 888 302 Ford
ezirider
Mercruiser 888 302 ford alpa 1,, changed out fuel pump
and found milky oil?? I mean milky where you put the fuel pump into the side of the engine,,,tell me whats wrong now or the possibilities thanks
jerryjerry05
Re: fuel pump change found milky oil 888 302 Ford
If that's the only place you found milky oil then It's probably just condensation.It might have gotten there from too much water in the bildge.
Clean it out and re-install ,lube the shaft and check it after using.Jerry
Ayuh,....
What's on the Dipstick,..??..?? That's what Counts....
ezirider
dip stick was fine.. milky oil was just in the opening
of the fuel pump (mechanical)
