Fuel pump changing, mechanical
Brucebu
Help, I just changed the mechanical fuel pump on my 1988 GM 350 Mercruiser in a Malibu Skier inboard. All is well but after I finished I had a bad thought, should I have greased the moving lever and parts in the pump before installation or does it get oil from the motor as it works. I am not happy about having to take it off and grease it but if I have to it will be a lesson! Thanks.
meesh
Re: Fuel pump changing, mechanical
A little grease for start up never hurts but it gets plenty of oil when the engine is running. You'll be fine.
