fuel pump for j150glera
poorboy123
can i buy a fuel pump only for a j150glera engine? i plan on mixing oil and gas myself.
Chris1956
Honorary Supreme Mariner
Re: fuel pump for j150glera
Normally you can cap the oil input to the VRO or OMS pumps, and just premix. Is your current fuel pump bad?
tashasdaddy
VRO conversion w/ pump still working
if the fuel side on your Pump is still working it is very simple. unplug the 2 line harness going to the oil tank, unplug the 3 or 4 wire harness, going to the Vro pump. cut and cap the oil line going into the motor. add oil to fuel tank, mix well, then remove fuel line at top carb, catching gas in a container, pump the fuel line bulb until you get premixed gas to the carb. you can tell as it will change color. put line back on carb, and go boating.
ezeke
If you use conventional lift pumps, two are required.
Converting an existing VRO or OMS to premix is the cheapest work-around. The gasoline side of the VRO/OMS is repairable with kits, but the oil side and electronics are not; the gasoline side can be maintained as a premix pump virtually indefinitely and it is much more powerful than the lift pump.
There is alsio a VRO/OMS look-alike that is strictly a Pre-Mix pump Part # 5007422
poorboy123
thanks to all who replied. going back with the vro pump. only $50 diffrence in the two. thanks to this forum i know what to do in case of an oilng prblem. again thanks to all who replied...
