sam60
- Joined
- May 21, 2011
- 3,189
454 with new fuel pump and rebuilt Holley 750 CFM is running fine until you get it over 1500 or so RPM. The fuel pump voltage should be 12V +/- .1 per the service manual and I am only getting 8.5-9.0V. The fuel pump relay is powered by the "light" terminal on the alternator and the "S" terminal on the assist solenoid. There are diodes in each of these leads to the fuel pump relay hidden in the harness.
Here's the voltages that I'm getting during cranking-
8.5 volts at fuel pump -- should be 12V
2.3 volts at light terminal from alternator -- should be 13.9 to 14.7V
Am I correct in assuming that I need an alternator?
I have also ordered a diode kit before they become obsolete, as I can't find the microfarad or whatever those are rated at.
Thanks for your advice.
