bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
Been testing some lower units using a 1983 60hp Johnson and ran into new issue with this engine.
Had engine running on muffs while testing to see that the lower would shift properly and all of a sudden it just quit. It will start and quit right away. Fuel issue again, found I have a portable tank that is collecting water. Sorted that out aleady. Now it will pump fuel to the pump screen but I'm not getting fuel to the float bowls. Pulled both drain screws and the bowls are dry. Just replaced the bulb a month ago along with all fuel lines.
So before I go pulling the carbs off should I look at the fuel pump or the new bulb?
