saltwaterbluefish
Thread starter- Joined
- Dec 14, 2010
- 156
I just took my boat out of winter storage. The outboard is a 1977 115 hp Johnson. Oldie/Goldie, put is still a workhorse. I had ran all the gas out of the motor and sprayed fogging oil in the carbs before I put her away for winter, which was not much here in NC.
Today, I put in new spark plugs and then changed the 8 inch piece of hose inside the engine that goes from the fuel connected to the fuel pump. Put new gas/oil into the empty gas tank and she started right up. However, after a minute she seemed didn't sound right, and that is when I saw gas/oil leaking out of the bottom of the air silencer that is covering the carbs. I quickly shut her off. Even when i pump the primer bulb, gas/oil is leaking out from the same place. I did take the outermost piece of the fuel pump to make it easier to connect the fuel hose, but there was no gasket to be replaced. I was wondering if this sounds more like a carb issue or could it be a carb and a fuel pump problem? I also last year had an issue with having to let the engine warm up for atleast 10 minutes before opening up the throttle because it would cut off.
If it is a carb issue I know I need two kits (Part # 18-7046), but do I also need the floats or needles? Additionally, if it is the fuel pump, do I just need to buy a new fuel pump altogether or can a newer model kit work? The manual I got doesn't do a good job of listing the exact parts that need to be replaced.
