Fuel Pump or kit for 1967 Evinrude Fisherman also correct mixture
wayhat
Hello folks I just purchased a Zodiac and it came with a retro 1967 Evinrude fisher man. kind of a neat old motor. It started right but would cut out every now and then and just die. I think the fuel must have been bad. I cleaned the fuel filter and then notice some dried cork in fuel pump so I tool it apart not knowing about the springs etc which where drop and lost. Wondering if any one knows the part number for the fuel pump kit or the whole fuel pump. As well should I mix this 50 to 1 or do these old outboards need more oil.
Many Thanks,
Wayne
tashasdaddy
Re: Fuel Pump or kit for 1967 Evinrude Fisherman also correct mixture
what horsepower is it. there is some contraversey over what fuel mix, it depends on the type bearings, that's why i asked HP. laingsoutboard.com has most of what you need. get a carb kit also, and clean the carb. idle settings are in the engine faq forum.
wayhat
Thanks folks for the responses the motor is a 6 hp.
Wayne
