fuel pump or (spark plug wire)
leafs
Re: fuel pump or (spark plug wire)
the connections on the gas line are new .the gas line connects to the gas tank is new with a new connection and the other end of the gas line that goes to the engine is new but the connection on the motor is not new ,there is no oring in there is there
BKool68
You could also have crud in the carb bowls. Take them off and check. Carb kits are cheap.
leafs
can a person just take the bowls of the carbs to check them and then put them back on or does this require taking them all apart and getting carb kits
sjksjk
Check your gas line fitting where it twists into the motor, make sure the new one on your hose matches the one in your motor. The one in the motor could possibly be worn and a little different than the one that came with your new hose. It could be restricting the flow. Just an idea, I am no expert. Presently studying at the school of hard knocks. Good luck. SJK
rolmops
Hello.<br />Leafs why is there a cookie hidden in question?????
leafs
i changed the fuel pump and took the boat out today. it worked great for most of the day untill i ran into some weeds, after that the problem came back with the revs,but the primer bulb stays hard now,i am hoping the moter just heated up a little and thats why i am having the problem again
leafs
on the 2nd ignition coil the spark plug wire that goes into the coil goes inside and twist. there is a small crack in the housing that keeps the wire securly in the coil.so it was loose i took it out and the end looked like it had corrision on it so i cut off the end and screwed it back in it seem to run better, won't know tell i take it out tommorrow.this is the second time i did this,would the coil or wire be bad or is it that i just do not have it screwed in far enough that causes it to corrode.
leafs
TOOK THE BOAT OUT STILL HAVING TROUBLE.how could the boat run so grat the other day and then have no revs.now its hard to start,once i get it stated i have to quickly push it to wot or it stalls and when i do go to wot it just moves slowly. could something eletrical be causing this.
twisted039
over the winter rebuild the carbs, get a manual.its not that hard pay att. check all cyl for spark .............next time out on the water run some carb spray in each carb under some good thoddle if one takes off really good u will need to check that carb...
leafs
the fuel pump fixed the problem but the head gasket started to leak that was the problem replaced the head gasket yesterday taking the boat out today.one problem the top cylinder wall is starting to score,mech says its bored out as far as it can be a sleeve would have to be put in 500.00 just for one sleeve
