fuel pump psi/to high
Westdevil
i have a 470/170 mercursie<br />what would happen if you used a fuel pump that psi is higher.
Bob_VT
Re: fuel pump psi/to high
Put a regulator in line with the feed line befor the carb. Your only risk is the fuel line where you run higher pressure. <br /><br />Bob
DHPMARINE
Just curious,but why would you want higher fuel pump pressure?<br />DHP
