Fuel pump question
j4ivi35
On the fuel pump in the pic im not sure what the hole in the green square is for? I know it not the inlet or outlet. Im thinking its just a vent from the crankcase but im not sure where it would go to? Its off a merc 140. Thanks in advance for any help.
Bt Doctur
Re: Fuel pump question
that should have a fitting that goes to the carb.it`s a vent line for the diaphram and uses a clear line. It also is a indicator when the diaphram fails.If you see liquid in it, the fuel pump has failed and needs replacement.
