Fuel pump rebuild and exhaust gasket replacement 1996 75hp ?
JD466US
I am getting ready to rebuild the fuel pump and replace the exhaust plate gaskets, they are starting to leak, on my 1996 75hp Force outboard. Is there anything I should watch out for when rebuilding the fuel pump? And should I use a gasket sealer for the exhaust gaskets, and if so, what type should I use? Also what is the torque spec for the exhaust plate bolts? I would hate to break one of those off.
Thanks,
JD
jerryjerry05
Re: Fuel pump rebuild and exhaust gasket replacement 1996 75hp ?
You run in salt??? Your chances of breaking them off while you take them out is GREAT!!!
PB Blaster then tap the head of the screw a bit then spray and tap again do this a bunch.It will loosen the corrosion and maybe the bolts will come out easier.
Me,I'd just leave it and spray with WD or a good silicone.
If you break ONE (usually the bottom ones) you gonna be down for a while!!
