Fuel pump relay fault ??
02809Bristol
2004 350 mag MPI . Throwing a “fuel pump relay fault “ ? Everything seems to be fine . No issues with fuel pump . I notice that there are 2 relays next to ECM . Which one is for fuel pump ?
or has anyone else encountered this issue
Could use a serial number, don't know if you have a 555 ECM/PCM or PCM09
The 2 relays are main power and fuel pump
The MPR has Red wire going in and Red/Purple going out
The FPR has Pink going in and Pink/Green going out (555 wiring, yours may be different)
Thanks, yes 555
Try swapping the relays (there the same part number), and if you need one they can be found at the local auto parts store
Click image for larger version  Name:	555 relays.jpg Views:	4 Size:	75.3 KB ID:	10883182
