Fuel pump same for a '91 35HP and '87 50HP?
Evinrude_NooB
Hi everyone and thank you for reading my OP.
Can someone please tell me if the fuel pump for a 1987 Force 50 will fit in a 1991 Force 35HP. The reason I ask is because, as you know from my earlier thread, my 50HP is toast and I saw a 1991 35HP, which needs a new fuel pump. I'm thinking of buying the 35HP and fixing that up if the only problem is the fuel pump.
Are the parts between the two compatible?
Thank you again.
Frank Acampora
Re: Fuel pump same for a '91 35HP and '87 50HP?
I can't tell you for sure, but I can tell you that repairing the 35 HP fuel pump will be easy and cheap.
I went and looked it up-- the two [umps should be interchangeable.
Evinrude_NooB
Thank you, Frank.
I looked for a new OEM, but seems to be discontinued. Ebay seems to have a used one for around $40 with shipping.
