fuel pump
danfish
how can you tell the top from the bottom when installing a fuel pump on a 9.9 force motor when trying to start motor getting to much gas to the spark plugs
JB
Re: fuel pump
Hmmm. Hi, Danfish.<br /><br />Don't know about the fuel pump. Guess that it will only go one way. If you are getting fuel to the carb it must be on right.<br /><br />Too much fuel when trying to start is a different matter. You might be overchoking it, but it is more likely that you have a stuck float in the carb.<br /><br />Good luck. :)
