fuel pump?
seaswirl71
well the engine is now running on all cylinders and idling well but after about 5 min it dies unless I pump the primer bulb then itll go for a while longer. Is the fuel pump the only suspect? all new fuel line and no leaks ?
kenmyfam
Re: fuel pump?
Tank vent, float sticking and fuel pump are the prime candidates in my opinion.
seaswirl71
Re: fuel pump?
so with this fuel pump for my 1970 60hp evinrude should I buy a new one or just rebuild it?
kenmyfam
Re: fuel pump?
I would just get a new one personally. Not an expensive item.
tashasdaddy
Re: fuel pump?
these fuel pumps will work. BRP#
Part Number: 0383765 Equivalent Parts: 0398385,0433390,0438559
Description: FUEL PUMP AY
does not show an aftermarket replacement
