capt. stabin
- Joined
- Jul 8, 2007
- 30
does anyone know where i can get a new fuel pump for my 1987 125 force?
Entire fuel pump is $150 bucks. Chances are if it is the fuel pump you just need to change the check valves or the check valve gaskets. valves are 5 bucks each part number is 21-F177330 the gaskets are fifty cents each
part number 27-F84792. You will need three of each. The valves are press fit into the pump and can be removed using a deep socket.
Air is less dense then gas. Gas might not get past those check valves as easy. Most fuel pump related issues I have seen here on Iboats has been at full throttle or at least cruising. I would be more suspect of the idle circuits in the carburators. Have you had them apart and cleaned?
