I've searched all over this forum trying to find anyone that may have a problem similar to mine.
I have a 1995 Force 120hp. Outboard is on a 17ft pro-gator bass boat with a built in tank.
My problem is when I pump up the primer bulb for the fuel it gets hard and it stays that way and I can start the motor fine and it runs great at idle/half throttle/wide open. I can run down the lake and fish for an hour or so and when I get ready to go to another spot the motor cranks right up and runs for about a minute till it runs all the fuel out of the carbs and then it dies. I always end up having to go back there and pump the bulb back up and it takes off and runs great, but if I stop for awhile I will have to most likely do that again.
Ok, originally I suspected the primer bulb, replaced it twice, finally got a good one on there. That didn't get it so I replaced ALL the fuel lines and fuel filters and made sure all the hose clamps where tight. Still didn't get it. I don't think it is the fuel pump because it runs good at all speeds once you get fuel up the lines. I have not noticed any fuel leaking from places. I do have the fuel in the carb covers from tilting the motor up while I'm fishing and trailering.
I'm stuck, the only two other things I can think that it could be is if somehow something is broken on the pickup tube going down in the tank or maybe the float needles on the carbs are bad. I think if it was the pickup tube than the bulb would never get hard because it would be sucking air.
Any help at all would be appreciated. About to pull what little bit of hair I have left out over this deal.
Thanks,
Matt
Thanks,
Matt
