fuel sender install w/sealant or dry
ShoalSurvivor
I recently installed a new sender with the arm lifting toward the front of the tank, just like the previous. The holes didn't line up perfectly, but I managed to snug it down. That was a mistake! it leaked with a full tank.
Today, I pulled it, separated the arm from the flange and rotated it so that the flange holes line up properly with the tank AND the arm bends in the correct direction.
I reinstalled with some form-a-gasket 3, on both sides of the rubber gasket, then snugged down the 5 bolts... however 1 bolt is slightly cross threaded and the bolt doesn't seat all the way down. The remaining 4 bolts thread down snugly.
I am able to get a solid 3-4 turns before the bad one bottoms out, and it's biting in the top threads, its in a really tight spot, and I don't have a thread restore kit.
I'm considering adding a washer on the one bolt and using form-a-gasket 2, instead of 3, but have seen mixed reviews on using any sealant.
Recommendations?
Thanks!
dingbat
Gasket (cork?) should be installed dry.
Run a tap through the messed up hole to clean up the threads. Install bolt with fuel resistant sealant
Chris1956
Honorary Supreme Mariner
Regular form-a-gasket is not usually gasoline resistant. It will disolve and cause more trouble.
Permatex makes a gasket dressing that is impervious to gas. It is not real common in stores, so it pays to get it's stock number and then see who has it.
Use a rubber gasket and the dressing, but first, try to chase the threads in the cross threaded hole so it will tighten better.
ShoalSurvivor
FIXED!!
Turns out that the replacement bolts were just a hair too long for my threaded inserts. I was able to snug them all down and it "felt" snug (w/ zero movement between plate/rubber gasket/tank), but with a full tank, there was a tiny amount of seepage. I added a washer to each bolt and did a test run, and it's dry as a bone... no sealant required.
