Fuel sending unit
Liberator 6
All,
Diagnosed the fuel sending unit as bad. Any tips (other than "be careful" "take your time") on swapping the old and new one out?
Thanks,
Rob
Silvertip
Re: Fuel sending unit
This is a job that does not fall into the rocket science category. Disconnect the positive cables on the battery. No sparks allowed during this project. And just so you've been warned -- no smoking either. Undo the old unit, replace the gasket and install the new one.
Liberator 6
I'll be on my back, upside down, third arm pinned behind my back, and squinting out of one eye trying to get a 24 inch float out of a 1 inch opening...
JAL51974
Little bit of a pain but not difficult to do. Make sure the surface of the tank is clean before you put on the new washer/gasket and sender unit otherwise you will be down there again...don't ask me how I know! Soapy water will show bubbles if its leaking.
ddennis
And don't use a lighter for additional lighting in the bilge either! LOL There are a lot of ways to get yourself into orbit around this planet....blowing up a boat is not one I reccomend!
