Fuel Seperator instalation
jakeb
Easy one for you guys...I have a 470 that I installed an electric fuel pump after the stock one croaked. I am putting a fuel/water seperator on and was wondering if it should be put on before or after the fuel pump?
The seperator is a Racor 120R-RAC-01.
Thanks guys
jake
Don S
Re: Fuel Seperator instalation
Before, always, any motor, any time.
zbnutcase
And you did wire pump through an oil pressure switch, right? 'nutcase
Fishermark
I believe that particular one has the see-through bowl. That is for an outboard only.
Use one that has a screw on canister similar to an oil filter.
