WhiskeyGun
Thread starter- Joined
- Jun 30, 2016
- 10
Model: J140TLESE, 1990 140hp
Story:
I had discovered my motor was running a bit cold on the starboard side. After running around in the boat for a few hours and continuous at last 20 minutes, I checked by placing my hand on the heads. Portside I could hold for a bit and seemed good. Starboard was barely warm. Other than that it ran pretty good. It did sneeze some idling back to the ramp. I returned home and flushed it with some clean water and again starboard side wasn't that warm. Anyways, I pulled the thermostat out and took it apart. I discovered what appeared to be red silicone wrapped up in the spring and vernatherm. Only place I've seen red silicone was on the water pump seal. I had a fun time cleaning that up when I replaced the water pump a couple years ago.
I tried flushing it (nothing really came out) and I bought two new thermostats and replaced them. Well after replacing them and running the boat on the muffs I measured the temps with a laser temp gun. Portside stayed around 120* and starboard was now 145* on top cylinder and 170* on bottom!! Way hotter than before. The water out the tell tale was pretty warm (usually cool). Well, I went to pull thermostat out again and this time I discovered a grey colored liquid all over the side of the thermostat that feeds into the little hole towards the block (cap and seat according to diagram). There wasn't any on the other side towards the thermostat cover. That grey stuff smelled like like gas! I took a whiff inside the thermostat housing and it reeked of gas.
I ran out of light but I will do a cold compression test (scared to do warm now). I did a warm check last July back when I was diagnosing an earlier issue they were 90 90 90 80. I believe 80 was on the cold but now hot side.
Has anyone ever experienced this or might have an idea how gas could get on the front side of the thermostat? Just trying to understand all the possibilities of how this can occur. Will/Should I need to pull the head off and take a gander? I took a peek into the cylinder with plugs pulled out. The plugs looked good and were not wet or anything. The bottom cylinder was clean, but the top had a bit of carbon but not a whole lot. I didn't see anything that signaled water getting into the chamber.
I just want to know the possible ways fuel would get up there or into the water system. Is it possible the head gasket is leaking now? Perhaps near the thermostat seat?
Didn't have any gas in there until after I changed the thermostat :-(.
Story:
