fuel squirts out a carb?
csisommout
hi, why fuel squirtting out a carb when keep squeezing primer ball ?
The had been cleaned and putting in with a new kits. motor run if manually choke it. thank you.
Rudi2
Re: fuel squirts out a carb?
Ok, I'll bite-- float not adjusted properly when carb was rebuilt, needle not seating ; allowing bowl to overflow and fuel to "squirt out carb".
R.Johnson
I should have went to the other forum, [ sewing without pin's]
lindy46
. . . Or if the float was old and not replaced, it may not be floating anymore.:)
csisommout
why the new rebuild carb kit comes with slightly shorter needle and a clip.
FOR 1964 28HP 2CYL, model# 28402m, Thank you.
psteurer
You may have got the wrong kit. As a fix, you may be able to bend the metal tab on the float to adjust for this. With a shorter needle, the float is likely too high in the bowl and the needle valve never closes. So the result is gas constantly coming out.
I really don't know this type of carburetor but usually the float is set so that it is parallel to the bowl when you hold the carburetor upside down. In this position, the needle valve should be closed. Test it by blowing into where the fuel hose attaches to the carburetor. Should not be able to blow any air in. Test it again by flipping the carb over and blowing again. Should be able to get air in. Possibly someone with knowledge of a 1964 carburetor can correct me.
tashasdaddy
screws not tight that hold the 2 halves. does it squirt out, or does it just run over? have you changed all fuel lines with alcohol resistant lines?
Knightgang
Or....Ok that pretty much covers it.
I think I can agree with these experts....... HEHEHE!!!:D
