Liberator 6
Thread starter- Joined
- Jul 13, 2006
- 50
All,
Got a new QJet carb in, and installed it, no problems except the fuel line from the pump to the new carb was a little too long so I had to remove the pump from the holder and it's "hanging" from the mandrel bent steel line (pump to carb) from the top, and supported from the fuel inlet hose on the bottom. There is not much pressure on the pump at all, it seems quite content but I know that's not the "right" answer. I decided to give her a whirl, and the boat ran great for about 2 minutes and then seemed starving for fuel, both at idle and WOT, in gear and out. Sounds like fuel filter to me, any other ideas? How about suggestions for a new fuel line that's 1 inch shorter? Should I cut and flare it myself?
Thanks,
Rob
Thanks,
Rob
