Fuel system
Beatyouthere
If the primer bulb collapses the fuel pump works very well.----Once a motor starts the primer bulb does NOT need to be hard !
I can't get the primer ball to get hard at all it is only gotten hard and maybe twice I started the engine hoping it would suck any possible air from the water separator I am starting to think the possibility is the water separator is mounted too high on the boat
dingbat
Primer bulbs don’t get hard
Can’t mount separator too high
install clear piece of tubing in fuel line between primer bulb and fuel pump to check for a vacuum leak
tphoyt
Is water separated a new install?
Probably a silly question but if the filter primed?
saltchuckmatt
When you run the motor does it clear up if you keep pumping the primer ball?
What are your compression numbers?
