Fuel Tank Aluminum Fitting Alloy Question
Bob La Londe
I am in the process of getting my little 16' flat bottom rigged back up after three years of sitting. I finished welding the hull last week, and I am getting ready to re-rig it. In preparation I bought a new fuel tank. The vent on the fuel tank has a straight aluminum hose barb. It would be really convenient if I could swap it for a 90 degree one. The problem is nylon doesn't mix well with gasahol, and brass reacts with aluminum. Aluminum hose barbs are not so easy to find retail. I can make one easily enough, but all I have on hand is some 7075 and some 6061 in bar stock large eough to make a fitting. Anybody from Moeller read this forum? What alloy are your fittings?
Bob La Londe
Well, I made fittings from 6061 and so far they are working fine. (freshwater environment only)
Not sure why I bothered to post. No feedback in nearly 8 years. Oh, well. Maybe it will help somebody else.
Willyclay
Thanks for the update. Your feedback may help somebody else in the future. Good luck!
Ayuh,.... In the many, many aluminum tanks I've seen, they all use brass fittings,.....
No problem with dissimilar metals,....
