roscozen
Thread starter- Joined
- Mar 8, 2008
- 98
i'm installing 2 new gas tanks in my boat, moeller plastic tanks. on top are 2 metal fittings. one is the fill neck tube , the other is the sender unit plate.
the fill neck tube requires an earth-end ground for static elec drain off and moeller suggests i connect it to a metal surface on the outboard or outdrive.
the sender plate has a fitting for a ground wire as one side of the power for the fuel gauge. the 2 fittings ( sender unit plate, fill tube plate ) are about one inch apart.
can i connect the 2 plates with 1 wire that goes to my outboard block?
seems like the 2 wires would go to the same location anyway...
