Re: fuel tank gauge doesn't work
Fuel gauges work off 3 things: power/return, float level determining sending unit resistance, and dash gauge deflecting as a result of that varying current. Oh, and the gauge and the sending unit have to match. Probably by now there is a standard whereby the common sending unit resistance ranges produce 0 to full scale deflection on dash gauges.
Silvertip can nail the numbers for you and after I post this he will probably pick up on it as my response will send it back to the top.
The float varies the resistance in the tank to somewhere around 30 and 250 ohms between empty and full or full and empty....like I said, he knows which way it goes. Put 12v across that and the current in the circuit varies as V/R. That current is what causes the needle on the dash gauge to deflect.
With all that said, you still have the problem of the float accurately being at the top of the fuel for full and at the bottom of the fuel for empty. Usually, one (you personally) causes an empty reading to be displayed with some percentage of the fuel left in the tank for safety reasons.
Now you know how it works, look for what doesn't fit the senario.
Mark
