Maxum21
- Joined
- Mar 8, 2005
- 219
hey, been having what i believe is fuel related issues with my outboard. I found a kinked fuel line which i replaced then decided to inspect the fuel pickup and filter screen which is usually on the end of the tube. only problem is when i slide the tube out the tank there was no filter or screen on the end. just an angled off edge. I did measure it and the tube is reaching the bottom of the tank. Does the filter screen need to be replaced or can i run it as-is? i do have a fuel/water seperator and an inline fuel filter up near the motor to prevent any debris from reaching the carbs. If it does need to be replaced do you know where i can find one? thanks
