I have a 1983 Johnson V4 115HP. I only have a 30 gallon tank in the stern. I'm looking at installing some auxillary tanks forward. What do I need to connect three permanent tanks to the motor?
I found this:
http://www.iboats.com/Moeller-Four-...1582638--session_id.869157627--view_id.392162
but it appears that my fuel lines are 3/8. Will a 1/4" valve cause too much restriction in my setup and starve the motor for fuel or is this the valve I should use? I was unable to find a true three way 3/8 valve. Just the one that did 1, 2, 1 and 2, and off.
I found this one that I htink is 1/2"
http://www.iboats.com/5-Port-Fuel-T...201582638--session_id.706170359--view_id.4517
But it's prohibitively expensive and I'd have to bush it down to 3/8.
I found this:
