Re: fuel tank question (Sea Horse Sailmaster 4)
Portable fuel tanks are not supplied with fittings. You buy what you need for your engine. At the tank end you can use a hose barb if you want to permanently connect the hose. Or you can buy quick disconnects. One set (male & female) gets installed at the tank and the other end needs the female connector that matches the engine. When you buy a new tank, check inside and shake out all the plastic debris that may be in there. I've have a habit of checking tanks when I'm out shopping and invariably there is a great deal of plastic bits in them. Why do I do this? That plastic clogged up the pickup on one of my tanks, sucked the primer bulb flat and stalled the engine. I reversed the fuel line, gave the bulb a few squeezes to blow the pickup clear and was on my way. Cleaned the tank when I got home and was amazed at how much debris was in that tank..
