Fuel Tank Removal & Capacity?
Hands on
Recently purchased a 1988 Renken seamaster Walk around cuddy 2008
anyone know the fuel tank capacity? was told 88 gal. guessing. Also after reaching our fishing spot in long island sound we un happily discovered the fuel tank was leaking into the bilge.Great! :eek: Proceeded to remove the deck access cover and found the tank incapsulated with foam any one take these out before? do i need to cut it out and replace aluminum tank w/ poly?
or can it be removed and patched in one piece? PPPPlease help if u can
Thanks it would be greatley appreciated
Hands on
Re: Fuel Tank Removal & Capacity?
For anyone else asking this question, it is a 89 gal. tank. The removal process is to drain,flush, fill w/water,remove all hoses and wiring, remove the front 22" with a grinder and cut off wheel,drain water, drill 2" holes-2, run a lifting stap through and raise ,alot of effort is involved. Once that is removed it allows you enough room to jockey the ramaining tank section forward to clear the deck and into the access port, once there proceed to jack and comealong till loose enough to lift out. replace reverse the process minus the cutting, may want to install a new sending unit while accessable. Good Luck:)
