mitch_houser
Thread starter- Joined
- Aug 26, 2011
- 25
If your screws don't grab the second time around, go to the next bigger screw size. Or coat the threads with a caulk or sealant like goop. Run the screws in but not tight, until the sealant sets up, then snug them down.
Good to know, My last two built-in tanks had stopped working at some point and after cleaning and retightening the connections, they started working again. Did not know there were parts to go bad other than a float ! Another old dog learns something new....If you have an ohmmeter you can check the sender, w/o seeing it. Disconnect the pink wire from the gauge. The pink wire should have some resistance to ground, say between 30 and 250 ohms, if it is good and connected properly.
However, I find that the senders are the first to go. The last one I had to change, had a break in the sender coil, causing it to be open.
