fuel tanks
nofun2
Hi guys new here on iboat and getting back into boating.
my old johnson died and I picked up a Suzuki DT 55 oil injected.
My question is can I use the tanks from the johnson and just change the fitting
at the motor? Also can I connect two tanks together with a "TEE"
and run the motor drawing off the two tanks at the same time.
thanks for your help bob
99yam40
Re: fuel tanks
If one tank runs dry before the other it will suck air
deejaycee_2000
Re: fuel tanks
Yes you can just change out the fittings, but I would rather put a switch over tap on the T-system so you can switch the tanks over when the one is empty ....
